August 13, 20223 yr Hi there I have a 2022 Cube Kathmandu Pro - just having issues with what air pressure is needed for the front forks in PSI or bar? Bike is being used for mainly leisure cycling roads and cycle paths. Thanks
August 13, 20223 yr Find your weight(inc riding kit) in Kg. Check chart, and use a high pressure pump (not a standard bicycle pump)to get the approximate pressure. Obviously less pressure will make it a bit more bouncy. Edited August 14, 20223 yr by AndyBike
