bosch range extender on cube
Im looking at somehow installing a range extender on my cube reaction hybrid.
It has the in frame battery but cube dont offer the kit themselves.
If i bought another kit say from orbea and drilled into the frame would it still work or is there any software limitations from cube that would prevent it from working.
you can only use bosch batts on there system as they use can bus coms to talk to each other so no other bms will work.
you cant even make ur own as if you cut power to the bosch bms it looses its can bus programming and bricks it.
you can get this but not sure what motor software supports 2 batts at the same time.
https://electricgarageshop.co.uk/p/bosch-dual-battery-mount-kit
