March 26Mar 26 7 hours ago, guerney said:I hope you and that dude are right - if Bafang has been watching their controllers being hacked over these many years, have taken note of the most frequently changed parameters, designed their new system accordingly for fewer grumbles, that'd be good for the Bafanging mid-driving world. Saves all that mucking about with programming cables and apps, pricier as they are now for the CAN bus versions, with parameters limited in scope. If 36V X 15A = 540W isn't enough, I'll be suggesting users buy smaller wheeled bikes to convert, or downhill MTB frames with higher bottom brackets to fit smaller wheels.They don't make it easy ! On my can bus bbs01 , on the display, you can set the power levels to a % of max power easily but setting the motor speed per level is not easy. You can slide the bar upwards for each level but it will hit a limit depending on the settings of the pas level above and below it. So slide each motor speed level upwards until you hit the limit, save it. Then you can increase them all again because the settings on each side have changed, save it again and repeat until you can set speed to 100% in every level Edited March 26Mar 26 by Peter.Bridge
