Macfrey kits on aliexpress
[ATTACH type=full" alt="Screenshot_20250529-103905-998.png]63338[/ATTACH]
Hard to comment...!
HMM, have put a direct link in, now
Same issue: your links do not display in the UK, at least not today, not on my device. If you are not in the UK, you won't be able to see what I am seeing.
Maybe you should say why you think that particular Brompton kit is good or better than others. It seems to be exactly the same price - just over £500 UK, so no obvious advantage over readily available alternatives, or a roll your own solution.
Well the battery\controller mount on the front bag block does look better than the TOPBIKEKIT setup;
Difficult to comment on the rest, the bike shown is not a geniune Brompton, so who knows if it fits on a standard Brompton.
The other issue, when buying from the far East, is to know whether the bits are standard easy to replace bits, so your not locked into parts just from them.
USA region set, marketing blurb appears for the curious.
Key Features:
• Lightweight design – Maintains Brompton’s foldability and portability
• Powerful 250W motor – Effortless riding with smooth power assist
• Three battery options – Tailored to different riding needs
• Easy installation – No modifications required, perfectly fits Brompton bikes
Transform Your Brompton into an E-Bike!
Designed specifically for Brompton folding bikes, this Brompton Electric Conversion Kit seamlessly integrates with your bike without affecting its foldability. Whether for commuting, leisure, or long-distance rides, this kit provides the perfect electric boost!
Three Battery Options to Suit Your Needs
• 36V 5.2Ah (Lightweight) – Ideal for short trips, compact and portable.
• 36V 7Ah (Balanced) – Perfect for daily commuting with reliable range.
• 37V 10Ah (Long-range) – Designed for extended rides and longer adventures.
250W High-Efficiency Motor for Smooth Power Assist
• High-performance brushless motor delivers powerful assistance.
• Low-noise operation for a comfortable and quiet ride.
Easy Installation, No Frame Modifications Required
• Perfectly compatible with all Brompton models – No need to alter your bike.
• Advanced electronic control system ensures a stable and safe riding experience.
Why Choose Our Brompton Conversion Kit?
Preserves Brompton’s folding capability – Lightweight design keeps portability intact.
Eco-friendly and efficient – Lithium battery for sustainable, green commuting.
Effortless riding experience – Power assist reduces effort, making climbs easier.
Order Now & Upgrade Your Brompton to the Next Level!
Sd791ef425a5f4c3682e32b94223542c0T.pngS2f5390d1148444aaa1459423700858d8B.jpgSa5aa1e5918f64ce897d584b9d407d2deu.pngS59d40b40400d4277a3ad0779d97203d7g.jpgS95a85348e81a4586bb4a399a2d70ef10P.jpgS8dc659cbffa84eaaa6de28740932a20dV.jpg
Looks pretty much standard (which is a good thing!) akm-85 motor, standard 12 magnet cadence sensor - I'd want the 10Ah battery. I suspect the one in the photos is the small 5Ah battery. Topbikekit I think use the lighter AKM-75 front hub motor
Yep, does look pretty standard stuff, not sure about the battery connector though.
But the Brompton is rim brakes on meagre 16" rims, so instant death on an electric bike, given some of the 'advice' I have seen ....................
From the side, the battery looks like a No.74 Sticky Bomb. Can it take out an SUV in a high speed collision? I worry the weight of the horizontal battery waggling up and down either end will twist and break the frame mounting bracket eventually, if plastic, with the blast leaving yet another crater in the road for my bike to fall into.
Edited by guerney
