10 speed with hydraulic discs
lukepearce85
Apr 21, 2019
My bike is 10-speed (SRAM Rival 1x10) with hydraulic disc brakes.
Can you suggest a rear-wheel conversion kit that will work with this set-up?
Thanks,
Luke
Laser Man
196
122
Michelmersh SO51
The MXUS XF08-CST kit from Woosh will take a 10-speed cassette.
(Best check with Woosh that the lowest gear will be usable though - the biggest cog will be very near the side of the motor).
Fitting hydraulic brake sensors is a fiddle, but perfectly do-able.
8,230
If the stack height of 10-sp is the same as 9-sp then any CST hubs will be ok.
If not fitting a throttle then no need to bother with cut out's.
Woosh or Yose CST kits.
8,230
350v that would be something.
They are marked 350w my one was etched/stamped on the gear side casing and is hidden by the cassette.
2,675
Strictly they are not legal as marked 350w. The law in this area (as in many others) is somewhat out of touch with reality. However, they have to draw the line somewhere, and a nominal 350w motor puts the bike into a totally different class. It is very unlikely to be an issue unless you had an accident. In that case it could be quite serious as technically you need MOT, tax and insurance; plus the cost of any third partly liability claims.
