2017 E-Silence EVO
30,381
No I wouldn't, poor rear frame geometry for no good reason.
E-Wheels
227
103
Tim,
What was the reason to go with the Alfine 11 in lieu of the Nuvinci. A commercial decision or other?
dinger19
234
178
65
Kent
We hope to have one at the NEC Cycle Show. Should know for sure next week.
We've gone for the 11-speed Alfine rather than the NuVinci
Sorry for hijacking the thread,but as Tim is proudly displaying forth coming stock in his 50cycles shops have you now dropped Kalkhoff due to really bad reliability problems your customers are having.???
  • Useful
Reactions: LeighPing
Tim
770
78
London
On the contrary, we're selling more Kalkhoff than ever and have put in a very large order for 2017 Kalkhoff e-bikes.
5,785
I agree someone got mixed up and put the top tube too high and the seat stay too low in total contradiction with basic geometry. Gustave Eiffel is turning in his grave! :)
30,381
And that's without even mentioning the carrier that's only supported at the rear, cantilever fashion!
The trouble with style based e-bikes is the £1000 added per engineering rule broken. :rolleyes:
Ted B.
54
42
43
Guildford
One may wonder why 50 Cycles will no longer be the exclusive UK reseller then, and why 50 Cycles is now diversifying to many other makes...
I'm looking at the rack and something doesn't look right. I hope that the mudguard is strong and stiff otherwise the weld on the frame is not going to last too long. If they had a sensible frame design, like Flecc suggested, they could've fixed the front of the rack to the frame. I agree that styling/fashion has been given precedence over functional design. Maybe the rack isn't supposed to be functional as a rack, but instead is a stylised mudguard stay.
Another thing: I can't see a join in the frame to get the belt off. There must be one somewhere to put the belt on in the first place. How does it work?
trex
7,703
2,671
this picture shows how this is done:
trex
7,703
2,671
I thought I saw a join about 1/2 " to the right of the right M6 allen bolt.
I may be wrong, it can be a weld, not a join.
The chain side support for the rack seems like capable of hiding the join.
The only thing I can see is that thing at the top that looks a bit like a strap with an axial bolt into the seat-stay, but it's not clear in the photo.
In the 45 deg on photo, there appears to be a join just below where the rack is fixed on the seat-stay. maybe there's a bolt on the inside.
countarthur
26
11
Wales
I'm looking forward to seeing the 2017 models :)
I understand that the Kalkhoff 2017 models will have an improved motor in that there have been modifications to current Evo motor and I'm told bearings will be larger. I read something some time ago on one of the sites that the bearings were not big enough?
30,381
The chainstay spreads wide and flatter at the front, so it may have two bolts hidden behind the chainwheel, enabling enough spread there to pass a belt though. It would mean removing the chainwheel to fit a belt, but given their very long life that's not a big problem.
Not a roadside job though!
5,785
I think the screws at the dropout hold a removable plate. The photo isn't showing the joins.
