I've scanned the thread l linked to above and it seems excessive voltage and 'power off / power on' shock at speed was causing the breakages so localised heat my be a contributing factor but it seems the voltage and shock are the main culprits....
The SB motor will be putting out far more than 154W at half the no load speed when climbing a hill! This is typically where peak amps are hit and the motor is at its best for hill climbing. Going slower than half speed creates more losses in the form of heat in the controller, wiring and motor.
As the motor slows down the torque will increase and due to the way the controller works using PWM the current supplied to each motor phase will be greater than battery current by some margin (The keywin controllers for instance are set for 2.5x the battery current) so a 15amp controller can be putting around 38amps into each phase in these conditions.
The controller does this by trading volts for amps, they are very efficient voltage to current converters just like a 'buck' converter so what you are trying to achieve is already happening automatically.
IE: the motor is already providing more power at lower RPM than at full speed, its the nature of the beast...taking some rough figures at peak battery draw, lets say 36v and 15amps under load = 540W out of the battery, take away 50W for controller and wiring losses (gross estimation) = 490W and the motor is approx 65% efficient at half the no load speed gives ~320W electrical power at the motor.
