If you have a throttle connector on your controller, all you need to do is join the three wires in the correct sequence. if you don't have a throttle connector, you must replace the controller with one that does have one.Hi all
Got a basis beacon and looking at installing a throttle….how do I go about doing this?
We always recommend a KT controller with any of their LCDs, but not LCD1 or LCD5, and LCD4 has small and awkward to use buttons but works fine. Cost about £80. If money is tight, then Brainpower ones are not too bad, but a long way short of KT.Ok thanks…..if I don’t can you recommend a controller?
