Can any one help me
8,241
Swytch aka panda bikes have a Brommie kits in their line up.
If and when they are delivered, the forum has been reassured many times this is happening except the rollout /delivery date keeps being put back. August in now the latest date given.
https://www.swytchbike.com/folding-bike-kits/
8,241
Most likely you will have to stretch your forks to fit a front hub.
Hub will need to be fast wound 320rpm or so.
Bmsbattery for 80mm hub, controller /lcd, pas.
Source a battery from the UK or Jimmy at Bga -reworking can make up a bespoke one for about the same as an off the shelf one and use better cells.
For info trawl through these searchs .
http://www.pedelecs.co.uk/forum/search/1866394/?q=brompton+kits&t=post&o=date
Warwick
731
225
Warwick
Think very carefully before investing in Swytch. It is a crowd-funded project and, as Nealh says, the delivery date keeps slipping. If you can wait for the project to bear fruit, it would be worth investigating, as their kits do not require fork modification. I am watching out myself, as I want to convert my M6L.
