Crank arm clearance
peter.c
1,611
491
thurrock essex
Has any one tried shimano steps e6010 crank arms, have a clearance problem the non drive pedal arm is catching on the chain stay of my latest creation these look like they might help ;):eek::oops:
a standard TSDZ2 73mm into a fat bike frame will post pic tomorrow The angle grinder and a hammer have been used:D
Reactions: Nealh
peter.c
1,611
491
thurrock essex
A few pictures of the victim, purchased as a scrapper with the bottom bracket threads stripped
I can confirm that the {on one} steel frame received 20mm cut off each side of the bb with a angle grindero_O that allowed the standard tsdz2 to fit in :rolleyes:
After spending much of the planning time on the drive side and chain line problems ,which are easily solved
Overlooked the other arm clearance :rolleyes: a temporary fix guilty as charged beat the offending item with a large hammer , then an even larger hammer this allowed for a test ride:D:D
but a solution is requred:eek:IMG_20200506_070521.jpgIMG_20200506_070537.jpgIMG_20200506_070557.jpgIMG_20200506_070623.jpg
peter.c
1,611
491
thurrock essex
The only item beaten is the pedal arm, the pedal now is not 90 degrees to the arm
Options are plug the hole drill and re-tap threads I do not think this will work ]
Find a new arm shorter or with a wider sweep
The worst part is due to the lock down cleaned the workshop up and binned all the old cranks Sure the original arms off the fat trike would of solved the problem
2,675
Did you try swapping the left/right crank arms, is this an option?
No, the right one has the connection to the chainring(s); also the pedal threading would be the wrong way round.
Kwozzymodo
177
40
Lincolnshire
Looks like you have space on the drive side, the whole crank unit needs to be shifted towards the non drive side. Have you installed any spacers on the drive side? If you have, can you move them all across to the non drive side?
cycling weakly
93
21
77
Hi Peter I have Shimano steps cranks on my Tongsheng. They have a narrower Q factor than the originals so they are not the answer. I don't think you will find any standard cranks with wider Q factor than your originals. If you got your frame as a scrapper why not find another one with a standard BB.
Steve
peter.c
1,611
491
thurrock essex
Thanks for the comments & suggestions
The rear tyre is a 4 inch + it is a fat bike, all have wide bb most 100-120mm
I just wanted a mid-drive fat bike with out the extra cost [£ double:eek:] and did not want a bbshd [ I KNEW THIS WOULD BE A PROBLEM BEFORE I STARTED THE BUILD:oops::rolleyes:o_O ]
The tsdz2 100mm conversion requires a 33mm tap and a full rebuild new shaft etc or a purchase from the US or Italy
We all know spare time and idle hands:rolleyes: with the motor and battery on the shelf and a pile of fat bike wheels tyres etc left over + I like a challenge;)
No spacers on the drive side the motor is tight up to the down tube and chain stays
Thanks for the heads up about the steps arms
The new arms are shorter [2inches] and steel so the grinder and welder [a cut and shut] should cure the problem, if not will wait for the local blacksmith to reopen and scratch build or move the bb forward
The problem will affect more conversions ,as new mtb now come with a small single chain wheel -100mm bb -11/12 gears and 2.8 inch tyres and crazy chain stay angles Carrera vendetta - Specialized Rockrider etc
peter.c
1,611
491
thurrock essex
Done and test ride completed standard TSDZ2 in a fat bike frame battle over ;):):eek:
The angle grinder and hammer are now locked away:oops::rolleyes:IMG_20200513_192524.jpgIMG_20200513_192443.jpgIMG_20200513_192538.jpg
peter.c
1,611
491
thurrock essex
Out in the wild big grin :):D just got to get the tyre pressure sorted tried 20 psi off road but 30psi is better on road less tyre roar 20 miles and still :D comfort seat and tmax seat post help
wheeliepete
2,047
755
Devon
It's a tricky one to get right. I run around 7-8 psi off road with Bud and Lou, but road noise is hideouso_O, 20 psi in VeeTire Apache slicks to avoid self-steer, but harsh and bouncy. Still work in progress.:)
peter.c
1,611
491
thurrock essex
The worst thing is purchased 2 new tyres put them on ,and after 100 yards back to the workshop to refit the old ones,:rolleyes: less tyre roar
Hard to adjust after a fs bike going back to rigid but its a great beer bike /shopper :p:eek:
