Deleting a post
30,415
How do you delete posts here please
You can only delete one of your own posts within 24 hours of posting it. During that period a Delete button appears in the post.
You cannot delete a post if it is the first one starting a thread. However you can edit in the first 24 hours it to say it is cancelled, invalid etc.
billyboya
1,031
88
72
uk
oh ok as I wanted some help on my controller on this link but seems no one can advise on it so thought I will delete the post I know a few but some I don’t like PO5 PO7/8 10/11
P00: Restore Factory Settings Set this value to 10 and switch to next setting, the display items will show all contents and restore original factory settings.
P01: Backlight Brightness (1: darkest; 3: brightest)
P02: Mileage Unit (0: KM; 1: MILE)
P03: Voltage Class 24V / 36V / 48V
P04: Sleep Interval
(0: never, other value means display sleep interval) Unit: minute
P05: Power Assist Gear
0/3 Gear Mode: Gear 1: 2V Gear 2: 3V Gear 3: 4V
1/5 Gear Mode: Gear 1: 2V Gear 2: 2.5V Gear 3: 4V Gear 4: 3.5V Gear 5: 4V
P06: Wheel Diameter Unit: inch Precision: 0.1
P07: Magnet Steel Number (for Speed Test) Range: 1-100
P08: Speed Limit
Range: 0-50km/h, parameter 50 indicates no speed limit.
1. Non-communications status (panel-controlled)
When the current speed exceeds the speed limit, the PWM output will be shut down; when the current speed falls to lower than the speed limit, the PWM output will be activated and the driving speed will be set as the current speed ±1km/h (only applies to assist power speed, not applicable to the handlebar speed).
2. Communications status (controller-controlled)
The driving speed will be kept constant as the limited value.
Error Value: ±1km/h (applicable to both the assist power/handlebar speed)
Note: The above-mentioned values are measured by metric unit (kilometers). When the measuring unit is switched to imperial unit (mile), the speed value displayed on the panel will be automatically switched to corresponding imperial unit, however the speed limit value in the imperial unit interface won’t change accordingly.
P09: Direct Start / Kick-to-Start Setting
0: Direct Start
1: Kick-to-Start
P10: Drive Mode Setting
0: Power Assist – The specific gear of the assist drive decides the assist power value. In this status the handlebar does not work.
1: Electric Drive – The vehicle is driven by the handlebar. In this status the power gear does not work.
2: Power Assist + Electric Drive – Electric drive does not work in zero-start status.
P12: Power Assist Intensity Range: 0-5
P13: Power Magnet Steel Number 5 / 8 / 12pcs
P14: Current Limit Value: 12A by default; Range: 1-20A
P15: Unspecified
P16: ODO Zero-Out
Long press the up key for 5 seconds and ODO value will be erased.
P17: (Customer Designated) Auto Cruise Option. 0: No Auto-cruise
1: Auto-Cruise On. Trigger time of auto-cruise is decided by the controller.
P18: (K5S, APT Protocol Bound) Forward / Backward PAS Option.
0: Forward. 1: Backward.
P19: (K5S Protocol Bound) Throttle Level Option.
0: No throttle level. 1: Has throttle levels.
P19: (K5S Protocol Bound) 6km/h Cruise Throttle Definition. 0: Throttle has no 6km/h cruise definition. 1: Throttle has 6km/h cruise definition.
