Hi,
Is there a derailleur hanger that would facilitate fitting a derailleur gear changer to a frame that is designed to effect chain adjustment by sliding the wheel backwards in a horizontal slot? - You know the one with the little adjuster on the end. (Hope I've described that well enough - I know it doesn't read well!)
In short I'm wanting to put a derailleur gearchange onto an old Ezee where the original had the Shimanao hub gears.
