Durable Mountain/City Bike around £2000-3000.
BogomilPetrov
11
Hey guys,
I really need some help in choosing my first E-Bike!
I need something with the following requirements:
1. Suitable for long travel and commutes, as I travel between cities (60-80 km is best).
2. Powerful pushing motor to go up steep hills, as I live in a very hilly area with long steep hills and want to go up them with ease.
3. Rugged and durable frame like a mountain bike, as I tend to like adventuring and going down bumpy and very uneven terrain quite sporty which would rattle any bike.
4. Something comfortable for the bumpy adventure rides and long commutes. Mudguards and Back/Front Rack preferred.
Budget: £2000-3000
The current ones I have stopped on after weeks of searching are:
Wayfarer H9 Hub-Drive Crossbar | Wisper Electric Bicycles (wisperbikes.com)
with Adventure Tires, Front Rack and 700W motor.
Neomouv MOUNTAIN 2 28'' T47 630WH KAKI (neomouv.com)
with 630W motor.
ENDURO | Hikobike
with 670W motor.
Haibike | SDURO Trekking 3.0 | Trekking eBikes
The current one which I really like and want is the Wisper Wayfarer H9.
The only problem with it is that, if possible, I would like to remove the speed restriction on any bike/model I buy while taking full responsibility about that.
The first 2 models in my list including the Wayfarer H9 are discouraging me as they have custom motors and I can not find any information about a way to derestrict them.
The latter 2 in my list seem to have options about how to do this but I am not sure which one to choose.
Would anyone be able to give me some guidance and advice on which one to get or possibly suggest any other models or bikes in my price range which fit my criteria?
Having said that I fully understand the reproductions of me wanting to derestrict the speed on the bikes and I am willing to take the risks on my own head.
Any bike suggestions would be very helpful even if they can not be derestricted. I just want a good choice in this price range!
-Bogo
6,319
well with the haibike if you fit a dongle the range will be about 25-30 miles depending how fit you are with a 500w batt.
for the range you want id look at bikes with a 20ah size batt or 1000w+
8,230
Fit a dongle to the highbike to derestrict it, the battery will last less so 50km might be ok but not 80km.
If BP sticks to 32km/h then he might be ok for 50km.
BogomilPetrov
11
Even if I don't go for the derestricting in the end which one of the 4 do you think would fit more for my criteria? Or maybe some other one?
It would be nice to have the option to have full speed but even without id rather have a good choice in my price range.
BogomilPetrov
11
Fair enough. Is the Haibike a good option then? Regardless of the dongle I'd rather have a good and reliable bike.
Which of the 4 options would be best and if none any other suggestions?
8,230
For range you need as much battery capacity as possible so the wayfarer with 700wh battery or the 670wh battery bike.
With the wayfarer one will get the best CS should a fault occur and they supply parts for their bikes up to 10 years old, once past this the bikes tend to be nearly obsolete.
16,466
for commuting, you should consider a hub motor and puncture proof tyres.
They require the least maintenance and likely have lower depreciation.
If you want to derestrict your bike, then consider a conversion.
For long distance, cadence sensor has the advantage over torque sensor because you can pedal less whenever you so wish.
6,319
the most i got from a 500w batt is 48 miles at normal bike speeds and climbing hills ect.
also the batts for these bikes are expensive a new bosch 500w batt is £633
8,230
Wasn't georgehenry quoted a lot more for a new yamaha battery ?
6,319
i still had the dongle on but with m8s on normal bikes but there super fit so if i did not have a dongle id be left for dust.
i get 25-30 miles if i floor it tho at 120rpm i can hit near 40mph but cant have speed and range yet and my hips are fooked at that rpm.
BogomilPetrov
11
Are you all saying that I should just forget about the derestricting and go with a normal bike? I'm just afraid it will not be future proof.
There used to be these electric bikes on a subscription where I am and I i used to ride them all the time and pay a lot of money.
Problem with them was that the restriction always triggered at certain point and made me pedal against the motor... It felt horrible.
If I go with a bike such as the Wayfarer H9, if I exceed the 15.5 mph limit will it start working against me to keep limiting my speed to 15 5 mph?
If I was able to use my own legs to increase the speed last the motor assistance after 15.5 mph then that would all be good. I just don't want it to go against me and try to slow me down to its "normal speed".
I can definitely pedal myself more than 15.5...not if a motor is working against me or whatever ...
6,319
no just if you want faster speeds the batt will need to be bigger my bike is 24kg and no point in trying to ride it past the 15mph cut off as like hitting a brick wall just with a dongle the range will suffer depending how fit you are and what mode you use.
3,004
My bike is about the same weight (with a bigger battery ;) ), and that brick wall was troubling at first - but now I can maintain a comfy 28km/h on the flat, after the electrical assistance has cut off at 25km/h. I'll need to TRT like Lance Armstrong, obviously...
16,466
no, we are not saying that you should just forget about electrification because you want to derestrict your bike or bikes. The law as it stands let you have a fast electric bike if you so want, you have to wear a helmet, share the road with cars where you ride because you are not allowed on paths where children may walk, get a number plate, pay insurance etc. The process is well explained here:
Now there is a distinction of breaking that law on a bike you bought from a shop and a bike you convert yourself. Suppose you run over somebody at over 15mph. Their lawyer will look at every angle that they can make a claim on. You can see that the shop owner and the bike manufacturer will try to avoid being sued. That is why doing a conversion yourself if you intend to break the current law.
16,466
yes, you can do that (use your legs at over 15mph) at anytime, like when going downhill. The motor has an internal clutch that eliminates 95%+ of drag or binding. Only the road illegal direct drive motor kits sold on the net have significant magnetic binding when pedalling without power. Not only that, they weigh a ton and they are used essentially to turn bikes into motorbikes with a permanent throttle, you can't realistically pedal them on your own steam. You often see them advertised as 1000W, 1500W, 2000W kits etc, they are worse on climbing hills compared to middle of the road legal bikes because road legal bikes are allowed to release a lot more power for a limited period when climbing hills, typically 500W-750W, you can still fly up the hills at up to 15mph. The direct drive kits don't have internal gearbox so can be slower than legal bikes on hills. If you only want to occasionally go little over 15mph on the flat, it's usually not a problem with legal bikes, they let you get to 15mph, then you can speed up from there.
BogomilPetrov
11
Thank you all for the replies!
I'm thinking more and more of never derestricting and just going with the Wayfarer H9 and the good customer support. (Unless there are other suggestions)
As long as the bike doesn't go against me on purpose past the cut off (motor working against me to limit my speed on purpose) and spins freely like a normal bike would then it seems like the best option.
Ill just pedal harder if I need to get somewhere. My only worry was "the brick wall" being there on purpose and not allowing me to pedal harder.
From what I understand it just stops the motor and leave the full bike weight for me to carry instead of making pedaling harder.
I have no intention in causing harm or breaking the law that badly. I just didn't want to struggle against a motor which was working to stop me on purpose.
I'm fine with a heavy bike.
BogomilPetrov
11
Also I guess my best choices might be the Wisper Wayfarer H9 or the HaiBike Sduro from what people here seem to have suggested of my choices.
One final time I want to ask if anyone has any other good suggestions from something that's not on my list, or some other one from my list?
I will make my choice today and buy it all today.
Also would the WAU bike that I see advertised everywhere survive a bit of rough handling? I tend to like going down stairs sometimes lol.
I will report back after I read a few more posts which will appear here with my choice and go and buy it!
Thank you all again for the amazing support!
I have considered what you all said very carefully and I myself am not sure why I would derestrict when I'd mostly ride it in people areas.
16,466
I'd like to go down stairs sometimes too, but I reckon you'd need good full air suspensions for that like Soundwave's bike. Mid range bikes have coil front suspension, OK for normal roads but not offroad.
Maybe he'd sell his to you for much less than you would expect. I have a second hand Sunn Shamann Finest full suspension bike (10.6kgs) that I am converting for quick on/off electric/normal for that kind of use.
8,230
The issue with highbike is warranty, after the two years are up any major repair or replacement part will be costly, where as something like the wayfarer will be much more reasonable.
Wisper Bikes
6,230
2,197
68
Sevenoaks Kent
Thanks Neal, and if I can chip in, we support our bikes for many more years than the bigger brands. And if we dont have the parts a complete upgrade of the electrical system to current specs (not motor as 95% of the time it's not needed) costs about £350.00 including labour and VAT. We have done a lot of these. That's one of the advantages of dealing with an independent family business!
All the best, David
