eBike stopped working - help!
UrbanPuma
634
41
Hi all,
I was cycling up a minor hill using throttle and pedal assist on my Powacycle Puma when the motor cut out. All power indicators still work and batter indictor, but throttle and pedal assist doesn't. Also, when I push the bike backwards there's resistance in the back wheel.
Any ideas on problem and advice?
Thanks,
Urbanpuma
8,226
Was it raining ?
8,226
Both going at the same time doesn't bode well.
Even if pas goes throttle should work independantly, sounds like something may have fried in the controller. Probably a mosfet has gone.
Disconnect the controller by unplugging the motor cable at the connector along the rear stay and if the wheel spins ok, then the controller is faulty.
Reactions: cwah
UrbanPuma
634
41
Ok, i'll do that and report back
cwah
3,048
179
www.whatonlondon.co.uk
Yeah check by unplugging the controller first. If you still have resistance backward it means somewhere your phase wires are shorting
UrbanPuma
634
41
I've added two pictures, I'm holding the motor cable in one - do I just disconnect the black plastic square thing?
wheeliepete
2,047
755
Devon
All of those wires in your hand need to be disconnected. There should be a plug near the motor which would prob. be easier.
UrbanPuma
634
41
Disconnected all cables now, back wheel goes backwards with just very slight judder - what should I do?
cwah
3,048
179
Ugly connection. Keep the phase wire separated and try running your bike now.
I think you got a short on the phase wires
Reactions: wheeliepete
wheeliepete
2,047
755
Devon
I had similar looking melted wires on a bike recently, but controller and motor were fine after repair. If the bike runs with the phase wires separated, cut out those connectors and solder the wires together. Tape them up well or use some heat shrink tubing.
UrbanPuma
634
41
Yes, I think you're both right about the short due to the wiring. Sorry, I'm not technical at all..how do I disconnect the phase wires - just pull them apart?
And what needs to be connected to test if the the bike works?
cwah
3,048
179
If it works, you better replace these connectors if you don't want that happening again
