Giant Lafree spares or repair
pdarnett
599
140
Bradford
www.mybigdaydj.co.uk
My local bike charity have acquired a Giant Lafree that they want to sell as seen. Needs a battery but looks complete. Offers around £100. Let me know if interested and I'll put you in touch.
30,381
This the 1999 to 2001 Lafree series which uses an SLA battery, basically 2 x 12 volt batteries in a casing, and a rear hub motor.
If it's complete the charger is built into the bike, mains plugging directly in.
stephen Harvey
27
63
Can you still get a battery for this bike ?? Which part of the country is it in?? Thanks
30,381
You definitely can't get a complete battery or casing from Giant, even the following model's battery has been discontinued.
The options are:
1) Find an old battery for it and replace the two SLA batteries inside. Most sizes of those are still available.
2) Fabricate a casing and contacts/connections and equip that with the two batteries.
3) Use a modern Lithium battery instead, ignoring the built in charger. That could either be with an altered case mounted as usual, or a standard battery mounted on the carrier and connections made.
