The S06P integrated controller:
http://www.bmsbattery.com/controller/578-36v-s06p-integrated-controller-for-new-bottle-case.html
seems interesting, due to dimensions (BMSbattery has told me it has a diameter of approx. 8cm).
The idea would be to buy it independently from the bottle battery which is supposed to be fit with (BMSbattery support has told me the controller can be bought independently):
http://www.bmsbattery.com/aluminium-alloy/620-bottlle-battery-case-for-cylindrical-cell.html
and to try to do the following:
Buy a cheap decathlon water bottle such as the following:
http://www.decathlon.es/bidon-15l-aluminio-id_8300664.html
1.5l, aluminium, not isothermal, with 8cm of diameter and 31cm length. Cut the base. Put three levels of 18650 batteries (e.g. a 3-4-3 distribution; I know who can sell me these cells), for 30 cells in total for a 10s3p configuration. Height is 19.5cm, so probably it fits. Also in diameter it should fit.
The problem is the controller. A standard, box-shaped controller would probably not fit. But the controller quoted above could be the substitution of the bottom we have cut before, once the cells are put inside the bottle.
Of course, this sounds great, but in practice is not obvious if it could be done.
I believe this is the same controller as the one included in:
http://www.bmsbattery.com/36v/571-bottle-ebike-battery.html
So, could anybody with this battery tell me how the controller is anchored / screwed to the bottle? Is it conceivable to use this controller as the bottom of the decathlon bottle linked above? (as said, diameters fit, but it is not clear if screwing would be possible, or possibly better gluing).
