Hi All
I have a had a Faultless Bafang kit with hall sensor wires which has been faultless UNTIL NOW !!!
I had a blow out on rear rear, tyre came off rim, tube was wrapped around gearing/brakes etc BUT when i last left it (was still using bit of power to get me up hill) it was all good...
I have just fitted a new rim/inner ONLY.
All connections are good and there has been o alteration to wiring...
I have DOUBLE checked the 6 pin connector going to motor and it looks fine, BUT the wheel is not turning BUT i can hear the motor inside the geared wheel spinning ???
Any ideas what i can check ???
Its as if the 6 pin sensor plug is not plugged in ??
Cheers
Cheers
