Hi from Northern Ireland
8,242
Welcome to the forum Curley.
Depends on what you want the bike to do, the terrain you want to cover and you fitness /weight also the range you need. For instance a light person can get away with a light weight kit but a lardy person will need something a bit more substantial. The average kit weight is about 6 - 7 kg on a bike but you could lose a 2 - 3 kg for a light weight build.
  • Useful
Reactions: LeighPing
tommie
1,760
600
Co. Down, N. Ireland, U.K.
Hi Curley,
from Co.Down myself, needed something to cope with the hilly terrain and rough back roads we have,
bought frame and front wheel (rest i trashed) on the local gumtree for £25, added all new parts after that plus the Bafang BBS02 750watt kit with battery, now in the process in doing away with the rear derailleur and fitting a geared Alfine 8 hub... you could say it`s become a hybrid bike now, copes with much everything.
only thing i`d say is don`t skimp on the battery, get at least 13aH and upwards
bike weighs in now at approx 23kgs and cost of the conversion kit plus the battery was around the £600 mark.
If you live in hilly parts, not as fit as you were, have injury etc then this is for you!
  • Useful
Curley
9
7
54
Northern Ireland
Thanks for the welcome. I am only cycling to work each day which is around 5 miles each way just a few small hills so I don't need something to powerful. It would appear they are loads of kits around but getting the right one will be tricky .
pgregg
9
N. Ireland
Hi Curley, Can't help you out on the kits myself - just wanted to welcome another fellow N.Ireland ebiker. I just got my bike, haven't had a chance to get out on it yet.
Angelnorth
209
170
Hexham, Northumberland
Hello!
I wonder if you might get more joy if you ask in the Conversion Kits section of the forum? Could be wrong but I suspect conversion specialists are more likely to see it there rather than in the intros section. Let them know what you want to achieve - Nealh's questions above are a great starting point.
