Hi i am new with a kalkhoff endeavour 10s
yogiellis
11
65
jersey
Hi I live in jersey , 59 and still fit ,but like my electric bike , but my bike fell over in bad winds , landing on the handle bar control , causing the control to open and rip the cables out , so I am hoping that some one knows how the wires go back into the control panel , cant afford £200 + for a new one , so any help would be great please see phots attached . Kind Regards. yogiellis
Reactions: davidhlm1
The markings are German for colours:
we = white
ro = red
br = brown
ge = yellow
gr = green
One thing, though: One of those wires carries battery voltage (probably red). If it touched any of the other bare wires, it would most likely kill your controller, which is part of the motor and not replaceable. when you attempt the repair, make sure that the battery is removed. Also, there's a capacitor in the controller across the battery wires, which will hold some charge, like a battery, so you must discharge it first by shorting the positive terminal to the negative, otherwise you can still damage the controller when the wire that has battery voltage touches any of the other pads.
