Hi
Domm
35
7
49
Sussex
Hi, I've been reading a fair bit about e-bikes and getting tempted /excited about the idea. But can't find any info regarding the weight of rider and what spec is needed.
I'm 6'5" (196cm) and about 110-115kg.
Would a uk legal 250W shift me up a decent hill or isn't it worth it?
Seems daft that rider weight isn't inclued in the uk regulations tbh as a 5ft 50kg rider would probably fly around on those specs.
Any advices/thoughts/opinions welcome thanks!
6,319
its 120kg for most bikes so you are ok and most will get you up a decent hill and 20 miles more.;)
Reactions: LeighPing
LeighPing
2,547
1,944
The Red Ditch
There really should be a 'Wanted' section in this forum. I'm sure that there's plenty of helpful members around the UK that'd let you have a go on their bikes. Subject to handing over the keys to your Maserati first of course. :D
Best to try one first Domm.
RobF
4,732
2,311
Depends what you mean by 'shift you up a decent hill'.
Full speed throttles are being phased out anyway, but you will have to put in some effort on a 250W bike to climb steep hills.
A lighter rider than you might be able to get up a hill faster, but there are other variables, you might be stronger which would cancel your weight disadvantage.
Trying a couple of ebikes will give you a good idea of what they are a capable of.
Some legal bikes climb a bit better than others, but the difference is relatively narrow.
Domm
35
7
49
Sussex
Thanks guys. I'm lucky in that there's a 50 cycles near me ( I think in an area with no hills though!) so I'll try some out.
Am I right in seeing this as a problem with the regulations though? Or isn't rider weight significant? If it is maybe they should be petitioned to change?
I don't really care about top speed on flat as I can manage that myself. It's dragging my lazy arse up hills that I care about! Specifying a one size fits all motor for this doesn't seem to make sense. I may burn out a 250W motor and a reckless 50kg teenager may be flying around dangerously on the same motor and yet be perfectly legal.
Reactions: Tabs and LeighPing
RobF
4,732
2,311
Rider weight is not as significant as you appear to think it may be - within reasonable limits.
The motors are relatively weedy, a 50kg teenager is not going to be pulling wheelies on a legal ebike while you struggle to get over the camber in the road.
Reactions: cyberdyne_systems
