The explanation is that the throttle is an option which when added to the standard unit only gives 6 kph and is minimal power sinvce the torque sensor isn't receiving any pedal pressure.I'm still puzzled by the very different accounts of the speed available from the throttle .
Tim, you did say that yours can take you along at 11-12mph -is this going downhill? Sorry, that wasn't meant to be cheeky,I'm just puzzled and genuinely interested to know what speed could be expected as most folk seem to feel the throttle is only of any use for walking alongside , which I accept is in itself useful but not in the way I'm interested in. Your further input would be appreciated, thanks
When the same throttle is fitted to the speed enhanced S models, the same kit gives around 11 to 12.5 mph, depending on the gearset fitted.
In other words, the extra speed is an accidental byproduct of fitting the walk alongside throttle to a much faster power unit. It's still very low powered unless you pedal at the same time though, so it has limited usefulness.
