Here's the donor bike:
It's supposed to be a gravel bike, but it doesn't quite have the relaxed geometry of a good one. It's good points are that it has disc brakes and it didn't cost too much. It's bad points are that the brakes don't work. I think this is an added arrangement, which might have something to do with that. It's convenient, but no good if it reduces the braking:
Not that it matters because all that's going to go. I'll be fitting carbon fibre straight bars and Shimano Hydraulic brakes. I'll be using the Shimano XT M766 integrated shifter/brakes because I love them and they take less room on the handlebars. This is all the stuff that's going to be added:
The motor weighs 1.5kg with its wheel nuts, etc. The stuff I took off weighs 1.5 kg, leaving the bike without brakes and bars weighing 7.95 kg. The total weight of what I'm adding is 3.0kg, so the finished bike without the battery will weigh 9.5kg. I'm looking at a battery weight of 2kg for stage one, then later, I'll go down to a 1.5 kg one. I think I can lose another 0.5 kg at least by changing the cranks and pedals to lightweight ones
