magura brakes
hech
352
27
argyll
Hullo again, and after many years I call for your help.
I seek a brake handle for a Peugot bike, a lovely s/h model called magura E 11 HS whom a customer of mine kindly left the right hand brake lever embeded in a passing tree.
So I am trying to replace the actual lever as the handlebar unit seems otherwise intact. If I have to replace the whole handlebar unit that's fine They are lovely rim brakes and it would be hideous if I had to replace all of it. Any suggestions ??
Greetings hech
6,324
hech
352
27
argyll
Thanks, Soundwave but the part you kindly located will not fit. I should have mentioned the brakes are Magura HS11 from 2011 and Id be happy to get the handlebar unit if I could find that. They are lovely brakes.
