Making Wiring extension cables
Andrew Wingrove
87
York
www.simplicityin.training
i want to make up some wiring extension cables with the JST connectors. I have the JST plugs etc, I just need 2,3,4 wire cable. Red black, red black white, etc. Had a search on amazon, closest I can find is alarm cable that is four strand with black outer. Is there a special name for these type of cables?
peter.c
1,611
492
thurrock essex
Be carful most alarm cable is 7 strand of 0.2 and is no longer copper [alloy mix] and only is rated at 12 volt one amp and the insulation melts if you draw to much current try ebay several sellers in the motor parts or boat part supply and in various colours and in short lengths and multi cores
Andrew Wingrove
87
York
Thank you Peter. The cables I am needing to extend on this project are the two x red and black from the brake handles, and perhaps the throttle. I think that these will need to carry 5V. I will check the motor and boat people on eBay as well.
Sent from my iPad using Tapatalk
Andy-Mat
2,214
562
77
Try a bike shop, an online one maybe....
8,242
