Need help
JamesWeekz
Nov 9, 2020
Newbie here....
I am planning to convert a Carrera subway 2 into a E bike, i'll be using a hub e bike conversion kit. The kit comes with a 7 speed freewheel but the bike has a 8 speed shimano cassette.
Would i have any problems with the gearing and the chain fitting if i used the freewheel that comes with the kit or would i have to change the chain and the shifting etc?
Any help would be appreciated! Cheers
8,250
Chain and shifter will be fine, one will have to adjust the derailleur stops as you will lose one gear, but better still if you haven't yet bought the kit look for a freehub/cassette motor.
Which kit you looking at ?
3,986
Newbie here....
Never mind the freewheel, isn't it important that you get the right kit? Show us what you plan to get and tell us why and what you expect to do with it.
Surf_Wonder
34
9
Its no problem, I removed the cassette, removed the extra gear that made it an 8sp/gear, then popped the (now 7 sp/gear) cassette back on the hub. If you don't remove the extra gear -its not an issue, you'll only be using 7sp/gears because of your shifter. Don't worry about your derailleur, most 7sp derailleurs can handle 8sp and not need changing unless your looking at 9sp.
Re - Batteries?Range? Ebikeschool.com was a huuuuge help in learning and understanding - the site doesn't look live but the info's accessible via wayback https://web.archive.org/web/20200130154941/http://www.ebikeschool.com/much-power-electric-bicycle-need
