Planet X Loxley E-Bike
www.planetx.co.uk
Use 15% discount code at checkout PXBANK15 (valid until Mon night)
Also step thru model same price
Planet X Step Through E-Bike
www.planetx.co.uk
Don't expect much support other than return if an issue within warranty, and I've not heard anything about this motor, but might be worth a looking at if funds are tight and the bike suits your needs and you're not interested in the cheapo ebay/amazon/sports direct cheap ebikes
The Planet X Loxley E-Bike is a versatile power assisted bike with long battery life, confident Shimano shifting and powerful hydraulic brakes. On a single charge the 374Wh battery provides up to 70 miles of pedalling assistance at speeds up to 15.5mph. The Acer Xplova rear hub motor provides 5 levels of support, ensuring you have the perfect amount of pedal assistance whenever you need it.
The Lightweight alloy frame supports the sleek integrated battery whilst alloy forks confident steering. With front and rear mudguard compatibility, the riding doesnt have to stop when the rain starts. 9 speed Shimano M3100 Alivio gearing provides reliable and precise gear changes whilst Radius Hydraulic disc brakes ensure smooth and controlled braking. 40mm wide Kenda tyres give reassured grip on a range of terrains plus added puncture resistance.
The fully integrated battery and internal cabling offers clean lines and enhanced weather protection. The battery is removed with a key for security. Both battery and rear hub motor weights are carefully positioned to ensure a balanced ride. Battery capacity of 374Wh / 10.4Ah and a range of up to 70 miles on one charge offer enhanced, worry-free support to help you go the distance. The battery charges in just 2 hours (6 hours initial charge)
The Planet Loxley E-Bike is powered by the Acer Xplova 250W rear hub electric motor system. Providing 45NM of effortless torque with the superb reliability you can expect from Acer. As required by law, the motor will automatically stop assisting once the speed of 15.5mph is achieved. Easy to use LED head unit offers 5 levels of assistance to ensure the correct level of power assist is supplied in the most economical way.
The Planet X Loxley E-Bike is supplied 99% assembled. Simply charge, rotate and tighten the handlebar and attach the included pedals to begin your journey. (4mm and 6mm Hex/Allen wrench required) Fitted with a sturdy kickstand for storage or just popping in the shop and reflectors supplied for a enhanced visibility
Note: The total travel distance will depend on rider and luggage weight, power settings and riding style. UK Charger plug supplied.
Size Guide
- Small / Medium = 52cm Seat Tube - 5 4 to 5 9
- Large / X Large = 56cm Seat Tube - 5 10 to 6 3
Weight approx. 19.5kg
