You get 100% of the quoted charge from a lithium battery; however, there is a slight caviat. You only get that number of watt-hours at a low discharge rate. If you run with high current, it can reduce by around 20%. The losses increase with the square of the current through each cell. That happens with lead batteries too, but not as much because they have a lower internal resistance.
