Q R Rear wheel
garyten
26
Following on from my recent post on Freewheels, i have taken the good advise to get a rear wheel that i can use Cassette's on, for my Woosh Big bear.
Will this Wheel fit my Big Bear frame. Click Here
It has a Quick release Skewer, does that makes it Narrower?
Woosh will not have a Sirocco Rear wheel until the end of September, and would cost £25, so i found this for only a few pounds more.
Many thanks.
amigafan2003
1,389
139
Should fit fine. Just to make sure, measure the distance between your rear drop outs - if it's 135mm (or withing a few mm) you're good to go.
I can't remember what bike you've got, but just in case, that one isn't suitable for disc brakes, otherwise it should be OK.
garyten
26
Thanks, i have the Big Bear, so no rear disk.
Im wondering more about the rear frame Dropouts, if they are all the same size, as i dont really know if wheel spindle/ axles/ skewers are all common diameter's .
I am also buying this one as its Black rimed, so it looks similar to the front rim.
Most Woosh bikes are fitted with Power circle wheels that i cant find anywhere,other than aliexpress.
The skewer will fit your bike. They're standard.
