Wisper Rack setting problem
chrisbach
9
Bought my 806 nearly 2 years ago but due to personal problems only now starting to use it. Unfortunately I am late in discovering some problems.
The rack on my bike does not seem to have been installed properly as the battery pops out. Having looked the top is aligned but not the bottom. It feels in place as I cannot pull the battery out, but after a short ride the power goes off. I am finding this a bit dangerous. I wonder if a new rack and bracket is needed...
Bikes4two
900
401
Havant
The misalignment maybe due to how the battery case is attached to the rack (e.g. causing case distortion).
If it were me I'd remove the battery case from the bike rack and then see how well the battery fitted, and take the problem from there.
8,241
If having issues speak to Wisper about it, one will find them quite good at trying to help out.
Reactions: Wisper Bikes
chrisbach
9
Thanks. I'll see if I can tell how it is attached.
chrisbach
9
I have emailed them now. I was wondering if anyone else had experienced the problem. I suspect it is a simple fix for someone familiar with it
