I have an Elife Cruiser with a 250w unbranded front hub motor in a 26" wheel. It's all very reliable and comfortable; I recently had a 70 mile ride without a problem, and I don't even regard myself as a cyclist. Rack battery mount, 2x 10.4Ah batteries managed the mileage easily.
The only thing I don't like is that the motor is a bit weak on hills. It gets up mild hills with some noise, fairly slowly but with little extra effort from the rider, but once you're faced with a long 12% drag you have to work hard pedalling in bottom gear, and with a cadence sensor it's very difficult to restart if you have to stop on the slope. That rather limits rides around the Peak District!
Woosh do a great-looking kit based on the XF07 motor. I don't know the torque figure of my current motor, but I'm fairly sure that the XF07 would be a huge improvement. My first thought is that I don't need any of the kit apart from wheel and motor. Is that just naive ignorance? I'm not keen to get rid of the 2 newish batteries I already own, the LCD display is fine and all the wiring and sensors are sound. But the controller will be for the unbranded motor. Is that a problem?
