SIROCCO CDL. Motor not assisting
crE
183
28
42
As the title says. Went for fora quick spin. No assist from the motor when pedaling :( I get full response from the throttle though. Nothing is going right this week!
Is there anything silly I've missed before I give woosh a call?
crE
183
28
42
Right. I've discovered it will assist for about 5 to 10 seconds and then the motor stops. Battery is reading full.
crE
183
28
42
The LED on the motor flashes a bit sporadically during the first few seconds when the motor works. Then just blips on and off relatively quickly when the motor decides it won't run
trex
7,703
2,671
the LED on the motor shaft is the pedelec sensor. Check that the sensor cable is not pulled. The LED blinks when you pedal. The motor should start after about 5 blinks.
If it does not blink in rythm with your pedalling, then the magnetic disc inside may be pinched by the silver cup.
crE
183
28
42
It's blinking now and the pedals are not moving. Constant blink. I can't see which cable may be the sensor
trex
7,703
2,671
if the LED blinks when the pedals are not moving, then there may be a poor connection somewhere between the sensor and the controller.
trex
7,703
2,671
you need to contact support@wooshbikes.co.uk to get the tool to tighten the silver cup. It may be quicker to go see them, they'll give your bike a service.
crE
183
28
42
I'm not sure what the silver cup is but woosh have sent me a tool for free (I paid for postage) and i had to buy something off eBay for the crank
trex
7,703
2,671
the silver cup replaces the traditional left bottom bracket cup. Remove the left crank, use a small philips screwdriver to remove the black pedelec sensor, then use the tool (the tool is C shape with two pins that fit into the silver cup) to tighten the cup well, you need to tighten it very well.
trex
7,703
2,671
possibly not, but you have to tighten the silver cup anyway. May be worth a trip to Southend. Typically, after the first 250-300 miles, everything needs tightening, greasing and also quite a few spokes need tightened up, the spokes and rims have settled by now. While you are there, Andy or Tony can show you how to do all these things, they can replace the pads/blocks for you FOC.
crE
183
28
42
Wish I was closer. 3 hours away! I'm in the west midlands. I may well make a weekend of it if I can't get my pedal assist working. Otherwise perhaps a service from a good bike shop?
trex
7,703
2,671
perhaps. Still, I'd recommend a trip to the seaside. They are open on Saturdays.
trex
7,703
2,671
Southend sea front has the longest pier, lots of cheap eats and a 7 mile cycle route. You can leave your car in their car park and your OH borrow a bike from their shop.
trex
7,703
2,671
that bit is not hard, QR front wheel, remove the stem and saddle if they get in the way.
