Spencer Ivy
Croxden
2,134
1,384
North Staffs
Has anyone any knowledge of the Spencer ivy bikes? I see they are made where the Kalkhoff are made, are they as good?
C
Cyclezee
Hi Croxden, Spencer Ivy are manufactured in Germany by Derby Cycles and are basically rebadged Kalkhoffs.
There are several marques with the same DNA, so fundamentally they are the same with identical Panasonic drive system.
Croxden
2,134
1,384
North Staffs
But Kalkhoff now have the Impulse motor, will Spencer Ivy change to this do you know?
30,419
Kalkhoff are also using the Panasonic unit still, also the Bosch unit and hub motors. They've tended to keep their own products like the Kalkhoff-BMZ battery to the Kalkhoff brand only, so I'd guess it may be the same with the Kalkhoff Impulse unit.
However, you could contact Spencer Ivy to check further.
RobF
4,732
2,312
The Spencer Ivy is similar spec and price to the Kalkhoff Agattu C8 Impulse.
Main difference seems to be Impulse drive rather than Panasonic.
I doubt most users would notice much difference.
The Kalkhoff has a bigger battery which would swing it for me.
2012 Kalkhoff Agattu C8 Impulse HS 50cm Electric Bike
Croxden
2,134
1,384
North Staffs
But you can get the Spencer Ivy from Amazon.co.uk at a better price.
RobF
4,732
2,312
The short answer is buy one if that's what you want.
But for an extra £150 or so you get 15ah instead of 10ah battery, hydraulic rim brakes and a parking lock.
No contest to me, although the Spencer Ivy looks a decent quality bike and should serve you well enough.
MS666
14
Does anyone know what the frame quality is like? from my past experience in the motor trade ive found that shiny bits are nice but if the chassis isnt up to scratch then its not worth it.
As the famous saying goes? "you cant polish a T#rd but .... but you can sprinkle it in glitter"
Nb - i'm not implying this bike is a T#rd as i wouldnt know :)
tillson
5,249
3,197
The bikes are produced by Derby Cycles. The frames and paint finish on Kalkhoff models is fantastic. I've not had any problems with mine and the paintwork is like new. The bike is coming up to five years old.
30,419
Seconded, they are among the best available.
