What happens if you have a 48v motor and you run it on a 36v battery?
I ask because I'm considering a 48v Lead acid install BUT i would like to convert to a Li ion battery or LiPo later.
Yes, a motor is wound with a particular RPM in mind for a certain voltage. If you under volt it, it will not run at the design RPM. However, if you overvolt it (within reason and limit current) it will run faster and give more power.
