sunlova kit packed up battery dead
stormb22
65
hi all i need new battery for sunlova kit how easy is it to replace, can i just get a 10amp lithium battery and change the connectors on the kit? seems to be few places in the uk that sell spare batteries anyone have any suggestions?
You can use any 36v battery, as long as you have a place to put it on your bike. Ideal is to put a switch and a 30amp fuse between the battery and the controller. To make a fuse, just get one of those flat 30 amp fuses for a car, and solder male and female bullet connectors on a short piece of wire each side, and insulate it. You can use the Sunlova switch.
Would you like me to have a go at repairing your battery (no cost from me)? If so, send me a pm with some contact details.
Scottyf
1,403
-1
i believe sunlova charged £220 for a replacement 10ah battery last time i emailed them.
Kudoscycles
Official Trade Member
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
LifePo4 batteries
We will have spare LifePo4 batteries available during June,price £208.80.....if you google LifePo4 look at the advantages of this battery type-1500 cycles,very safe,low self discharge,no memory effect,tolerant temperature rang etc etc. Lower energy density but only 20% heavier than LiMh
Dave Elderfield
Kudos Cycles.
stormb22
65
Ok thanks for all your info sunlova currently have the battery hopefully they may replace it
stormb22
65
Battery
you can use any 36v battery, as long as you have a place to put it on your bike. Ideal is to put a switch and a 30amp fuse between the battery and the controller. To make a fuse, just get one of those flat 30 amp fuses for a car, and solder male and female bullet connectors on a short piece of wire each side, and insulate it. You can use the sunlova switch.
thanks will bear that in mind if they don't replace it appreciated.
