If possible, I'd appreciate advice on whether or not I would gain an advantage by soldering the shunt on my controller: I'll try to provide as much relevant information as possible:-
I fitted an 8fun kit, front motor, to my Carrera Kraken mtb about 6 weeks ago:
I use the motor in low assist when on trails with the family, as speeds are low, medium assist when I'm on the road, particularly when trying to keep up a bit & keep high assist for b@ll-breaking hills
I don't need more speed - If I'm doing 15 mph I don't need assistance; my legs'll cope, but I could do with a bit more grunt on those hills, to ensure road speed stays above 8mph as I understand that, below this, I'll waste power as heat.
With the front wheel off the ground:
low = 12mph : med = 15mph : hi = 18mph
When riding, I get useful assistance to:
low = 10mph : med = 12mph : hi = 15 mph
If I solder the shunt, will I get more grunt At these Speeds, or will the speeds increase along with the grunt? (which I don't really need).
Now for the 64,000 dollar question....
Are my battery & controller up to the job?
Controller:
Rated current 7amps
Max. current 14amps
Battery, with panasonic cells:
Continuous current 15amps
Pulse current (10 minutes) 18amps.
I've recently bought a 2nd hand 2009 Powabyke X6 LS (Brushed motor)for my wife, but the battery only has a range of 8-10 miles, so I'm thinking to get another of the bottle batteries, from 8fun, to put on her bike: flecc warned that the brushed motor on her bike would be more demanding on a battery than my brushless one.
Does anyone know if the battery as specified above should be OK?
8fun controller:
Powabyke controller:
Controller:
Rated current 7amps
Max. current 14amps
8fun controller:
