hard to give too many thoughts if you have not tried all the bikes personnally so i will go on what i know, i bought a naff 1 speed folder which fortunatly had a fault which meant i could send it back, i had 2 lapland 36 volt battery bkes with battery withing the back wheel, both of which had faults so they went back, and then i bought a synergy/eddison.......in a flat area with no wind its a extremly fun thing to ride, it doesnt accelerate like the clappers but not bad and straight up to the restricted limit, its very comfy with great suspension, too mush as you have to tighten the spring right back as you bounce along like a kangeroo which not energy efficient,no rack which is bad or facilities to put one,it folds very easily and compact and better then the Quando as when folded you lay it down and it rests on a metal bar just below the main chain wheel wheras the Quando rests on its stand which and although stable on one direction due to the two wheels next to each other, the other way only has about a 3-4 inch rock befor its over,something im going to have to look at when i take on the train.the synergie is as light as they come at about 20kg and although quality gears its undergeared like most small wheel bikes which means you pedal with no aim at doing the speed which the motor can give...HOWEVER..i sold it and took it to sheffield today to its new owner simply because technically speaking its got no balls...ie 24 volt battery...any wind or slight gradient and speed was down to 10-11mph.........but as a non luggage transporter for camp sites car boots ect where its not hilly or windy..lol...its a brilliant ride....
the other folder ive had is the Quando which i got yesterday, tomorrow maiden trip...first glances which ive done a thousand of...cos its here im my living room
...it looks fantastic too....not pretty and wimpy like the synergy did, but stylish,strong, a excellant frame structure shape, nothing like the picture on 50 cycles site where i thought it looked a monster....excellant luggage rack at the back,again very easy to fold and as its a firm joint when you fold the front wheel round to the back you can lift up the front and pull it where you want as the two rear wheels being a foot apart make it stable and not wobbly, my other folders all where awkward after folding, plus this is 7 inches longer which makes it easer for pulling along....i dont mean towing behind a car either i mean to where you are shoving it out of the way...the synergy had throttle right side which was awful where this is left, all i can go on till tomorrow is all what you read about it in reviews which all state its superb, especilly for hill climbing and if you are able to tinker a bit like Flecc then this has to be the ultimate all rounder in all areas as at 23.5 kg the only way to get lighter is a 24 volt battery which makes the bike lose the power factor,having looked at all folders, much to Fleccs annoiyance as i kept asking about them
..the few other 36 volt ones are unknown quality, most of which if you read the small print the warranty is given not by the seller but the manufacturer who is always in another country..at least leicester isnt that far....if you weigh up the evidence at the moment i cant see any other folder being better, even without Fleccs tinkering.....
