I finally got around to fitting this controller and when I first opened up the motor it made very loud horrible vibrating noises and barely moved. I looked at the motor sensor connection (5 wire block) and noticed that the green and the blue wire on the controller side were swapped over compared to the motor (gree to blue, blue to green) so I swapped them over and tried again. It made it a bit better - now it spins at 10 mph (should be 20) and is still making an extremely horrible grinding vibrating sound. I've checked all other connectors and can't see anything obviously incorrect. Does anyone have any idea how I can get this wired up correctly?
The motor is definately still ok because it still works ok with my other controller.
