Voilamart 250w kit
Armadillo
17
I have a Voilamart 250w rear hub & the controller has only one level of PAS. Is there any way I can fit an LCD to this to give me better control, or do I have to buy another controller with LCD ?
8,230
The controller will be anologue so you need a digital type with 5 levels of PAS, KT with lcd3 is the most user friendly type on the free market. Buy a complete package of controller, lcd, PAS, throttle and brake cut off/levers for about £110 or mix and match compatible components.
Old syle wiring kit
Or Julet kit
If you want a low power kit go for the 6 mosfet 14a kits and not the 9 mosfet 22a ones. Not forgetting you can reduce the current with all KT controllers by at least 5a.
8,230
It is one of the Brainpower controller kits they are a bit temperamental to set up by all accounts and low power 13a. You still need a Pas and a throttle if you want one, if you have these then simply solder the correct wires together and heat shrink as the connectors will likely not match.
KT is the best most used after market system available.
3,986
You need to check whether your motor cable has he white wire in it. If it doesn't, you'll need a separate speed sensor for the LCD to show speed.
Armadillo
17
Does anyone know if the Voilamart 250w motor controller is sine wave or square wave ? Also - How much difference would it make to have a 13A controller as opposed to 15A ( I have a 36v 15 Ah battery )
8,230
Tell us how many pins the motor wire connector has, 3 is unsensored/Sq wave & 8 or 9 is sensored/Sine wave the 9th wire being for int spd sensor.
Controller current rating depends on the cells used inside and their CDR (current discharge rating) 15a will give a little more watts output.
3,986
15% difference in power (torque) and battery consumption.
Armadillo
17
8 wires so must be sine wave. It has quite good torque at the moment & don't really want to lose any of that so I guess I'll be looking for a 15A + controller. - Thankyou all !!!
8,230
If changing and you opt for KT go a bit more and 17a you can always dial the current down.
8 wires is indeed sinewave you would need an external speed sensor which you probably already have wiring it in is easy as KT have a separate wheel speed sensor connector.
Armadillo
17
Thankyou ! Also it takes about 6-7 revolutions for my PAS to cut in. Is this normal ?
8,230
KT & Luishi controllers are pretty much instant 1/8 of a rotation, how quick PAS engages is down to the programming mainly.
Armadillo
17
Thanks !
Have fitted KT controller & it works very well. Only about half a turn for PAS to cut in. Also throttle does not affect the PAS I can use either or both. - There is a grey wire ( EABS ) something to do with flexible braking - what is that ?
8,230
I think it might be for brake regen which doesn't happen with geared hubs.
8,230
The 6 fet ones can get very hot (to hot to handle at times) and need to be in free air for cooling, if they are in a bag of any kind then there is no air circulation The ali case acts as a heat sink for the mosfets, a combo of slow speed and high power esp on hills causes the mosfets heat to rise which is why the case becomes a hot potato. You can add extra heat sinks to the case to try and help, add a small 5v fan or two, place it in free air or attach it to the bike frame and use the frame as a heat sink.
When mosfets reach their max temp they cut power until cooled (thermal cut off) and the bike is powerless it may take 5 -10 mins for them to cool sufficiently for power to flow again.
I do use 6 mosfet ones and have no issue on my commute/town workhorse, on my 700c Boardman ( more of a touring set up) I had issues and opted to use a 9 mosfet larger controller for better heat control.
Armadillo
17
Thanks! Is that a square wave or sine wave 9 FET controller - not sure which is best?
