Where to buy Hailong 2 base?
smdts
22
I am struggling to find what I think is a hailong 2 base in the UK, and only 1 shady looking Chinese Ebay seller has something that looks similar. I bought a used ebike that came with 2 batteries, but I want to use the second battery to do a conversion on a different bike. Can you take a look at this base and does anyone know where I can find one, preferably in the UK if possible?
8,230
Hailong commonly use a 4 pin connector which are rectangular shape and not round pins, though I have seen the five round pin connector type.
Hailong and Polly case use this type of discharge connection.
8,230
Battery pic from the top side.
8,230
It's not a Hailong 2 either as they are a side off battery & base.
8,230
smdts
22
Thank you, I couldn't find anything in the uk, so I ordered a base of the coIMG_20200606_102740.jpgrrect dimensions with the wrong connector then ordered the correct round pin connector from aliexpress, so on the slowboat. To get a wee hurl in the meantime I discovered an xt60 connector cut in half fits the female side on the battery perfectly so I will glue a bit between the 2 halves and make a plate to fit the battery temporarily until it arrives.
egroover
979
579
56
UK
