Yose 36v 350w running at 48v on a KT controller
MontyPAS
390
148
Bought and fitted a KT LCD3 / T09s controller to my Yose 36v 350w powered bike.
Previously running a crap Lishui unit.
Whilst the combo works great on a fully charged 36v battery. A fully charged 48v battery shows 54.8v, and the controller will not turn on.
Is 54.8v outside the working parameters?
Also when coming to a complete stop the speedo takes a few seconds to do the same. It runs on. Which setting governs that?
TIA!
8,230
54.8v might be just calibration error of the meter, it shouldn't be an issue. But just in case drain the battery by 0.5v and see if everything works ok.
MontyPAS
390
148
Checked directly on the terminals, with two multimeters. A calibrated Fluke and a cheap and cheerful Lidls special. Both show the same. Also the blue tooth BMS indicates similar.
So it looks like 54.8v is too high a starting voltage for the KT to handle?
Will stick it on my BBSHD bike to drop the voltage down a few volts.
I have similar issue with my TSDZ2, it will not start with the battery fully charged, needs a starting voltage of sub 52v.... pants!
Reactions: Scorpio
3,986
KT controllers have a memory of some sort. If you already ran it with a 36v battery, it probably still thinks you have one. Try disconnecting the battery and short out the connector on the controller side to discharge the capacitors, then, if that doesn't do it, reset the LCD to factory settings.
MontyPAS
390
148
Thanks VFR, I was going to try a C10 reset if reducing the voltage (doing a couple of miles connected to my BBSHD) if it does not wake the controller up.
From your extensive experience, should the LCD3 / T09s combo work without issue at 54.9v ?
MontyPAS
390
148
Tried both of the above.
Discharged capacitors.... No go!
C10 Reset.... No Go!
Burnt off some of the voltage on the fully charged EM3EV 48v pack, from 54.9v down to 49v (Used it on my BBSHD bike for 5 miles), and all working.
So looks like the KT is fussy on voltage.
Ideas?
Sturmey
546
308
67
There is a L1 setting after the C settings that locks the controller LVC. I think its normally set to 0 for auto but can be set L1= 1 for 24v, L1=2 for 36v, L1= 3 for 48v . Any possibility this is wrong?
MontyPAS
390
148
Sounds a possibility?
How do you get into the L settings?
Sturmey
546
308
67
you hold down the 'arrrow up' and 'arrow down' buttons together for about 7 seconds or more after going through the p and c settings, you get into the 'L' setting menu.
MontyPAS
390
148
Tried that without success. Must be a different F/W revision?
Charged the battery to 85%. Kept a check on the bluetooth BMS. 85% gives a starting voltage of 52v.
Plugged it in and works no issues!
MontyPAS
390
148
54.8v is good for a fully charged 48v battery buddy. My 48v system shows 54.8v when it’s fully charged.
Agree.... Unfortunately the KT / LCD3 combo will not work above 52v. Hence only charging to 85% of capacity.
Reactions: Terry777
8,230
You just got to go with whatever works. 54.8v is no good if it won’t get you off the mark! 52v is the man all day long! Lol
Very strange that one MontyPas, never had an issue with KT's at 13s fully charged at 54.6v.
MontyPAS
390
148
