18AH battery for Kalkhoff Pro Connect S 2010 300W motor
lookpo
19
PCs? My question was do I need special battery for 300W motor of Kalkhoff Pro Connect S ?
tillson
5,253
3,197
Sorry, PCs = Pro (P) Connect (C) s.
50 Cycles the UK Kalkhoff dealer supply that battery new with the 300 W Pro Connect s, so it will be ok.
30,859
Tillson used the abbreviation PCs for the Pro Connect S.
I believe it uses the same battery as the standard bikes. However, I am not absolutely certain since the 300 watt unit on the Flyer X bike uses a special 15 Ah battery and it's Panasonic unit has a wider battery base for that.
If your Pro Connect S was supplied with a 10 Ah, 12 Ah or 18 Ah battery, it's the standard fitting and the battery in that advert will fit.
N.B. Crossed with Tillson's further post.
tillson
5,253
3,197
Crossed with flecc. I would advise you to take notE of what he says. He knows a lot more than me about these things.
tillson
5,253
3,197
I have 10Ah battery with a sticker "for 300W motor only".
I don't know why it has that sticker on it. If possible check with the supplier of your bike.
30,859
I agree, that is ambiguous.
It could either mean the battery platform on your bike is the larger type like the Flyer X bike has, or it could mean the battery is altered to match the higher motor power rating.
A check with the bike supplier is essential before buying a replacement.
Tim
770
78
London
The word from Cloppenburg is that the 18Ah battery is perfectly compatible with either motor set up.
