9-tooth sprocket for Panasonic
GORDONAL
333
sunny Powys(Wales),Spain
Having just read the thread on a larger Panasonic battery can I have advice on a change to my 14 tooth sprocket 11 's seem unobtainable at the moment is 9 a change too far.My needs are not huge range on my present set-up but more climbing ability would be beneficial.
30,859
You can't change the older 14 tooth sprocket on the previous unit for the 9 or 11 tooth sprockets on the new unit Gordon, the mounting is different. I'm not aware of any alternatives for the old flanged 14 tooth currently.
I'm guessing you have a Lafree?
GORDONAL
333
E-Motion City D/L. 2009 I thought a change to 11 was certainly possible?
30,859
Sorry Gordon, I was thinking hub gears since this often crops up with them, and I was forgetting the Emotions! I'm not familar with the size of motor drive sprocket they use.
If you do mean the drive sprocket on the motor unit, changing from a 14 to a 9 seems too drastic since that will slow the cadence drastically, the power coming in only over very slow pedal rotations. Also the top assisted speed would drop from 15 mph to about 9.5 mph, very low. Even the 11 tooth will have quite a lot of those effects, the top assisted speed dropping to below 12 mph.
Changing the rear cassette for one with a larger low gear sprocket but keeping the upper gear sprockets the same will greatly improve the hill climbing without those performance ill effects, so I think that's a better solution.
GORDONAL
333
Thanks again for your reply
