ThanksMost hub motors have an automatic clutch so don't give any resistance above the speed they are helping.
I think for now I'll settle for 328 rpm and see how that goes. I've had a good look around Topbikekit so will probably goes with them, they look a bit more professional that BMSBattery. Thanks400rpm is fast for a geared hub and usually these higher winds are found in Direct drive hubs.
If bent on needing 400rpm or more then you will need to over volt the 36v 328rpm 250w Q100c from Topbikekit.com. Limit the controller to < 17a and it might last or replace the two stage planet gears with metal ones.
Member Cwah has tried and burnt a couple out (I believe) and users on ES have also burnt them out by exceeding 20a.
Also watch out for the forum troll who will likely pipe up with his cut and paste as usual.
So when you are riding your pedelec and you set the throttle at a fairly slow speed, will that speed be maintained up a hill without having to increase the throttle? In other words does the controller try to maintain a constant speed or constant power with a given throttle setting? ThanksThat's true for motors with brushes, eBike motors nowadays are brushless and the speed of the motor is varied by adjusting the timing of pulses of current delivered to the several windings of the motor.
The controller acts as a current source, regulating the timing and current supplied to the motor. If the required current/torque is low then the voltage developed across the motor will also be low and it won't matter what the battery voltage is provided it's greater than that developed across the motor and isn't so high that it damages the controller.
Higher current controllers are, as their name implies, capable of providing higher currents and its important that the battery has a high enough voltage to provide that current, when required, into the motor load and is also capable of supplying that current.
I hope that answers your question.
Indeed 30mph would be illegal on a public road and quite rightly!Some controllers are programmable to allow usage & support for different wheel sizes. If you have such a controller, simply change setup to a wheel size that is smaller.
Disclaimer, I have never myself tried this, but theory suggests that it might work fine, though some controllers do not allow other wheel sizes.
But do not forget that exceeding the allowed max speed (if that is your intention), you might make yourself liable to possible prosecution, if the bike is not correctly registered for that new performance.
Scooting along at say 30MPH on a public road, makes you very obvious to the Police.
regards
Andy
Umm, not convinced yet, but there's time! In order for speed to be controlled by pulses to the winding the controller would need to know the maximum rpm of the motor then distribute power across the throttle range, otherwise the maximum speed would defined by the controller regardless of the motor rpm. On a £15 controller that seems like a lot of complicated electronics and two way communication with the controller. Much easier to use the hall sensors to run the motor on maximum all the time and vary the voltage to change speed.That's true for motors with brushes, eBike motors nowadays are brushless and the speed of the motor is varied by adjusting the timing of pulses of current delivered to the several windings of the motor.
I don't know of any model of controllers that work the way you describe.Umm, not convinced yet, but there's time! In order for speed to be controlled by pulses to the winding the controller would need to know the maximum rpm of the motor then distribute power across the throttle range, otherwise the maximum speed would defined by the controller regardless of the motor rpm. On a £15 controller that seems like a lot of complicated electronics and two way communication with the controller. Much easier to use the hall sensors to run the motor on maximum all the time and vary the voltage to change speed.
legalities aside, there is no geared hub motors for this sort of sustained speed.
The load is proportional to speed cubed.
You would need 1500W+ and a direct drive motor. Also, post your question in the speed pedelecs section:
I've no experience using a throttle on an ebike, perhaps somebody else can answer your question. Sorry.So when you are riding your pedelec and you set the throttle at a fairly slow speed, will that speed be maintained up a hill without having to increase the throttle? In other words does the controller try to maintain a constant speed or constant power with a given throttle setting? Thanks
constant current.In other words does the controller try to maintain a constant speed or constant power with a given throttle setting? Thanks
i had a go on a 750w bafang mid drive last night pretty much turned up to the max fitted to a toys are us bike and when it kicks in you are going 25mph in seconds with a throttle and with effort from peddling could go as fast as my bike does easy problem is it takes 15m to stop with rim brakes and eats the batt using itI've no experience using a throttle on an ebike, perhaps somebody else can answer your question. Sorry.
Please address the problem from your own point of view, "How does a controller KNOW the wheel diameter 100% accurately?I wonder, do you believe everything you see using Google? I'm not saying that the contents of your Youtube links are incorrect, I can't be bothered to watch them, but you seem to suggest that if something shows up using Google it must be correct.
most controllers do not need to know the wheel diameter nor RPM.Please address the problem from your own point of view, "How does a controller KNOW the wheel diameter 100% accurately?
It is true that some controllers have it burnt into the firmware, nobody can change it. And some, like my own bike, you set up the wheel size in the firmware with a password on the LCD display.....From memory only, I can set mine to 20", 22", 24", 26" and 28".
But the controller cannot "check up" the actual wheel size, it has to "believe" what I tell it!
Anyone with some programming experience will understand that fully, but if you are not programming (notice that I do not say "computer") literate, you may not!
Happy New Year
Andy
"How does a controller KNOW the wheel diameter 100% accurately?" - presumably you're referring to the rolling radius as measured between the centre of the axle and the closest contact point on the road. It's impossible for it to know that with 100% accuracy.Please address the problem from your own point of view, "How does a controller KNOW the wheel diameter 100% accurately?
You really should research your lies before you make your wild suggestions. As a professional electronics engineer I program in many computer languages, recently Python, C, C++ and some visual programming environments and in the past I'm programmed in Basic, Fortran, assembly language and machine code amongst other languages.Anyone with some programming experience will understand that fully, but if you are not programming (notice that I do not say "computer") literate, you may not!
