If you are bored, or even if you are not, now is a good time to do maintenance on your seat pillar. A neglected pillar will eventually rust into the frame and be very difficult to adjust or remove. First mark the current position of your seat, or measure the height. Loosen the clamp bolt and remove the pillar from the frame. Clean it, grease it and reinstall it. Job done.
