Hello,
I have some general questions about A123 battery (& similar) configurations and wiring.
I'm thinking about hooking two 6s2p packs in series to give me 39.6v, 4500-4600mAh. Apparently turnigy make the individual packs, see here:
HobbyKing Online R/C Hobby Store : Turnigy 4500mAh 6S2P 30C LiFePo4 Pack $69.99
Or I could get the ebay seller that jerrysimon bought his a123 cells from to make me a custom pack:
6S1P 16.5V2300mah A123 NEW Battery Pack for Models-2 on eBay (end time 04-Jan-10 11:50:13 GMT)
(the link is to a 6s1p, but they offer a custom build service)
My first question is about balancing the 6s2p packs. What kind of balancing plug would the pack have? In the photo of the turnigy 6s2p pack in the first link above it looks like there is only one 6-way balance plug, but there are 12 cells in the pack. How can you balance 12 cells with only 6 pins on the plug? Or is there another balance plug hidden under the visible one? If there is one plug, are they balanced in pairs? If so, surely one of the pair could be higher than the other? Or isn't that how they work?
If each pack actually needs two balancing plugs then that will mean four plugs in total, which would make the charging and balancing procedure rather cumbersome.
Second question, can 2 such packs actually be connected in series? And if they can, is there a way to do all the balancing on all the cells via one balancing plug?
If there is no obstacle (such as "it can't be done"
) I would be keen on getting two custom packs made up by the ebay seller. One 6s2p pack will just about fit inside a standard drink bottle, having two drink bottle batteries is appealing because of the unobtrusive aesthetics. Otherwise it would have to be a ping 36v 10Ah, which I'm not keen on, admittedly it is small but it is still quite blocky. I have already found out that ping are quite restricted in configuration due to the fact that their v2.5 packs are made up of prismatic cells.
Thanks in advance,
Chris.
Thanks in advance,
Chris.
