Advice for shallow dropouts
tomaquet
Jun 9, 2024
I've recently installed a 350 W rear-wheel motor and I'm a little concerned about the shallow dropouts (aluminium frame). I had previously gone out for a test-run and the wheel came out of the non-drive-chain side dropout (luckily the cable and myself were not damaged).
I examined the dropouts again and realised that the axle was not completely seated (drive-chain side) - I filed a very small part of the dropout so that the axle seats as deeply as it can (see photos). But the torque washers still don't look like they are sufficiently supported in the dropouts. I also think that maybe the bolt nuts to secure the wheel were not as tight as they should be.
I bought a couple of cheap torque-arms (jubliee-clip style - before reading that they are generally rubbish) and so far have attached one (on the non-drive-chain side).
Do you think this is enough to stop future axle spin-outs?
Should I attach the second (jubilee-clip) torque-arm?
Should I buy and attach a better torque-arm?
Should I file the dropouts (and hanger?) to make the axle seat deeper in the frame?
I know it's not an exact science but all thoughts welcome!
Thanks, T
Photos to show the current setup (the bike is upside-down in all photos):
https://i.imgur.com/iQl7s3o.jpeg
https://i.imgur.com/jlyRvB9.jpeg
https://i.imgur.com/Ll9odLy.jpeg
https://i.imgur.com/F0orT0a.jpeg
https://i.imgur.com/aWRSqV3.jpeg
Images folder: https://imgur.com/gallery/shallow-dropouts-ebike-3tvJ1sU
matthewslack
2,583
1,669
You look to have plenty of axle length to work with, and a fairly large flat area around the dropout.
I would make my own anti rotation plates from say 4mm or 5mm aluminium sheet. A close fitting axle shaped hole - not a slot, a hole, much stronger - and then drill and bolt to those flat areas. Probably M5 minimum bolt, and might have to be countersunk head to keep clearances OK.
4,131
You have plenty of room to file/grind the drop-outs a lot deeper, which you should always do if you can.
8,811
Nice drop outs one can easily take 4mm out of them to sit the axle lower, filing needs to be good and tight though then add a one piece custom torque arm to the LHS .
tomaquet
Jun 9, 2024
Thanks for all your comments and suggestions.
I think I'll file the dropouts 4 mm and then look for a better torque arm solution. Making my own custom torque plate is a little difficult as I dont have the tools available although obviously that would be the best solution.
8,811
One doesn't neccessarily ned to take out 4mm , it was just a comment I made looking at your pics.
The depth you need depends on if one is fitting the tabbed washers and wanting the tab to sit in the drop out.
tomaquet
Jun 9, 2024
I took out maybe a bit less than 4 mm in the end - just enough for the torque-washers to sit in the drop-out. The axle sits deeper and more securly now. I was wondering if was possible to flip the the torque-washers but decide it was better to have the axle as deep as possible instead.
8,811
One can flip the T washer if one wishes, all that matters is all of the axle flat sits in the drop out .
