My controller seems to have finally given up the ghost today, or at least that's what I think is wrong.
My bike cut out a couple of times late last summer on longish climbs and the controller was almost to hot to touch. The motor has never got hot or even warm.
Today it's cutting out every few hundred yards, it's not hot, just warm and starts up again if I disconnect power and then reconnect, but only for a short distance.
The 36 volt battery is fine and is fully charged at slightly over 42 volts, all wire connections are good and I've tried a spare throttle with no improvement.
I have throttle only, no pedal assist or display and don't use the brakes cut outs.
I'm happy to buy a new controller even if the fault turns out to be something else (nice to have spares) but wondering if there is an alternative to buying from Cyclotricity as around £60 seems a little on the high side but maybe I'm wrong in thinking that.
This is a picture of my existing controller before I fitted the kit almost four years back.
I'm not a genius with electrics as you may guess from the tone of this post and don't want to get into opening up the controller with my 69 year old non too steady hands. Any advice on a replacement will be much appreciated.
Edited to say I'm OK with soldering.
Dave.
Dave.
