Hi all, having decided 4 days ago that I am going to start riding to work rather than get a new car when mine goes off lease in 2 weeks time and for other reasons. I have done the journey a couple of times on my MTB and know my fitness level needs some electrical assistance to make happen everyday in a reasonable time scale.
Having read through a lot of different posts on here since Friday when I discovered this wonderful forum I have changed my view from just buy a cheap! new e bike around the £1000 mark and hope it does what i need which sounds unlikely from reading a lot of posts on here!, or to convert my 2009 Diamond Back Sorrento hard tail mtb which is in good condition with a lot of upgrades done over the years. ( I like to modify most things, not very good at leaving things as standard
So time scale to get parts and fit etc is 2 weeks which I assume will discount the BMS options that seem favourable on here due to delivery times?
So I am looking at a 26inch wheel rear hub drive (if my general reading on here is correct that it is a better option than front wheel drive?)
It seems UK stock availability seems to be limited at present where I have been looking but have found this 250/500w kit from Cyclotricity on the powerbikes site which going by the details on the site will fit my bike fine.
https://powerbikes.uk/shop/conversion-kit/dual-power-250500w-switchable-conversion-kit-rear-wheel-motor/
with the PA and torque arms, and either a 14ah totalling £594 or at a push the 21ah which works out at £694
Is this a okay kit or is there more better options available in my time scale for delivery etc?
My route is mixed road, cycle paths, gravel paths, country lanes and even a few bridal ways depending which route I take.
The distance is 12.5 - 13 miles each way and I am a 44 yr old male 5'10" and 100kg and not the fittest anymore. The elevation chart of my average route is below if that helps?
Charging the battery at work is not an issue and as I tend to work 10-16 hours a day it will have plenty of time to charge which is more than I can say for my legs and fitness after my shift!!.
Many thanks in advance for any help and advise.
Steve.
Steve.
