Advise sort on a my new Bird
3,923
I just found out from reading a chaps add on GT that the Bird Bafang Rear hub is actually a 500W motor that is restricted I assume with the Bird controller which is good news so I probably keep it on the bike.
That makes me now wonder if the new 4 Bafang Rear hub motors I have in stock from the Somerby Pendalton old bike but new unused motors are also in fact 500W but also factory marked as 250W does any one know if this is the case ?
If you look at the windings inside the motor where they're terminated, you'll see that the wires are bundled in parallel. Let's say that there are 120 loops of wire around each pole. That could be 5 turns of a bundle of 24, 6 turns of a bundle of 20, 8 of 15 10 of 12, 12 of 10 or 15 of 8. Whichever it has, the windings would look identical, but the motor would have completely different speed and power characteristics. They also use slightly different thickness of wire to give even more combinations.
Bafang motors used to have the number of turns written on the outside of the motor, appearing as a number in brackets ranging from 6 to 16, with 16 being very slow and 6 being very fast.
63138
63139
Baz the balloon man
390
18
OK amI right in saying that the RM number CO10250D 15 1 under thatF6V2040933 are the number you mean so 15 1 at the end is the speed ?
I assume as it’s Bafang it’s a very good quality motor are they ok to go up to 48 V for a bit more torque?
Baz the balloon man
390
18
Worth the effort to put into a different rim ? But then the rim looks sound to me I might just have to spray black to match the front on a Raleigh Array or buy a silver front rim.
Or spray chrome effect on the front wheel not sure how that would look
I had an interesting few e mails with a guy in the States he said The Hunan Wisdom Company make the original OM Bird Batteries and any other company selling them in China should be avoided problem as they pack in after around six months is they have an MOQ of 50 pieces so he is sending me a few defunct ones so I can get the battery guy to do a quality re cell here.
So I think to keep the Bird Bafang if it gets a new lease of bird life
Baz the balloon man
390
18
In my limited experience checking the motor drawings of Bafang hubs shows that the 500W and 250W motors have different dimensions. The 250/350W tend to be identical. You would of course have to know the model numbers to check this.
Just posted photos on Saneagle thread have a look see what you think
3,923
Baz the balloon man
390
18
Just had contact from the original manufacturer of Bird Bike Batteries Hunan Wisdom Company .
They say both 9.6 AH and larger spec batteries use the same Canbus System so should be compatible with bikes sold in the UK
Problem is they have or did have before Tariffs a MOQ of 50 pieces according to from a contact in the USA.
If any one looking for a replacment original battery get in touch .
Baz the balloon man
390
18
Hi all
I have now found and bought a non functional Bird bike battery the bike had done about 2500 miles before the guy scraped it.
Photo attached.
So for the proposed new build on the bike I am planning to replace all the cells and and put a non Canbus BMS on it so I can put the KT kit on and keep the Bafang Rear Hub drive as the rebuild looks like a low miles bike .
Any help before I take to the battery company would be appreciated.
Safely opening the battery .
And possibly just dropping in a new battery replacement pack complete with non Canbus BMS even if I have to buy a whole new battery to remove the battery pack from
Available drop in space without opening is around 330mm X 45mm.
I would like to get it up to around 14AH as I have been advised that there is not enough space to fit 48V.
I intend to sell the bike once finished so have to keep an eye on the budget
Hopefully this will post will assist other members with Bird Bikes or Vanmooth in this style who can not get new spare parts anymore and think a new e kit is the way to go.
matthewslack
2,453
1,613
What warranty do the battery company give, and what liability do you take on when you sell on a modified bike and battery?
I think you need to be quite careful: you seem to be running a business working with risky things and basing your technical knowledge on forums and the like.
Reactions: Cadence
Baz the balloon man
390
18
Battery company give different warranty s on their work .
But as of yet I do not know if they can re cell the battery with a new BMS that will work with standard kits .
I do not see why not if the Canbus communication is taken out .
Seems a shame to split the bikes up but that is probably what will happen .
T
Baz the balloon man
390
18
T
Morning Matthew
Would you have a problem with a battery that’s brand new with all its original components in place just effectively having a change of case so a simple re connection of positive and negative input and out put terminal s if the work is done by a competent person and providing a fit good could be found?
And any battery pack replacment was a good fit ie with no movement for instance .
Using a lower end of the market brand like HL that has no Canbus communication but is considered safe enough to be sold in the UK. Around the £200.00!mark
What would actually could cause any potential risk or danger in your opinion?
