UPDATE:
My Agattu i snow coming to the end of it's third winter season, and I will be glad if it is still running at Easter.
The bike has managed 5000 miles and estimated costs are now £2500. That's 50p per mile.
Cause of death: a lot of play in the motor sprocket. Perhaps I will have a go at replacing the motor bearings but this looks like a difficult job.
I have a new Tasman in the shed and will start using it when the winter is over.
Agattu summary:
Faults when new:
* chain tensioner not working. Spring was pinched between bolt and motor block by dealer.
Problems during first year:
* motor assembly wobbled from side to side. Solved by tightning bolts to frame.
* chain guard broke.
* chain broke at ca. 2330 miles.
* during winter brake blocks need regular replacements.
* hydraulic brake leak (Magura brakes fitted by dealer).
* battery begins to show signs of age.
* salt corroded copper strips in rear mudguard causing rear light failure. Replaced with two core cable direct to rear light.
* stand broke twice. Eventually replaced with solid stand.
Problems during year two:
* battery terminals corroded by salt causing power failure. Solved by scraping away corrosion. Battery display on handlebars incorrect now.
* spokes are starting to "pull through" rim on back wheel. Salt damage.
* brakes rubbing rims when not applied. Salt has corroded slave cylinders so they do not return to rest position.
* rust on shock absorber and luggage carrier parts (not stainless).
* chain broke again at ca. 3340 miles. Only lasted 1000 miles.
* rear light is eating batteries.
Problems during year three:
* new rear rim required
* play in motor sprocket
* shock absorbers (front, seat post) seized up
As regards the quality of Kalkhoff bikes, I can mention that I bought a mountain bike for £800 a few years back. It didn't even manage 1000 miles. The Kalkhoff bikes are great. My original battery still works ok too!
Thanks for all the support I've received from the forum.
Regards,
--Lazyviking
Agattu summary:
Faults when new:
Regards,
--Lazyviking
